Timing Chain Tolerance
The Dart GT
1963 Dodge Dart GT Convertible
USA
I'm rebuilding my 225 and when I pulled the timing chain cover I noticed just over a half inch of play in the chain (slop). Is that acceptable? Thanks
Photos required, please. Lets see the sprockets.
There is some gaping from chain stretch, is it too much,I don't know.
I wouldn't run it, it's just going to get worse.
If you're "rebuilding" the engine, I can't conceive of not replacing the timing chain.
Looks like it already had an upgrade replacement timing set on it at one time. Step it up a notch more and get a true roller for it. And while your in there. A Mother Thumper Cam and a header.
I bought a 225 not long ago with a hole in the timing chain cover because the sloppy chain wore through it.
