Timing Cover Date Codes
GTXperience
Orig Stealth Mod
Sacramento Area, CA
I have two timing chain covers (both with timing marks on the LH/driver's side & the same casting number). The first one pictured is easy to ID (Jan, '74). The second one is a little more confusing because the only two digit number is a 69 outside of the date stamp/circle. I was also thrown off by all of the markings in the month areas in the outer ring. Can anyone shed any light? TIA.
PS Is the second set of numbers under the casting number a possible date code. For instance, (05102) meaning: May 10, 1972. If so, shouldn't the second set of numbers in the first pic (09194) mean: September 10, 1974?
