340Dust-her
Upon replacing all freeze plugs on the 340 motor, i've come across the motor with no timing tab on it. The motor is a 68' 340 and I've come as close to have it run, but it boggs on high RPM(4k-5krpm). Anyone know where I'm suppose to mount the timing tab and the correct timing setting? Thanks in advance.
It does have a mopar performance electronic ignition. No points type distributor.
