69signetv8
Can't seem to time motor correctly. The damper's timing mark "is" at 0 @ TDC compression stroke however during timing with the light the mark must be 45-50 degrees off. "Connected to #1 plug of course". If I rotate the dist either direction trying to find the mark (of course the motor stalls out). Anyone know why I can't time it with a light?
The motor was rebuilt and I believe this is the correct damper. I have been timing by ear and vaccume getting about 18-19 max then leaving it.
Thanks
Thanks
