wireweld
Why do you hook the vacuum advance up to manifold on some distributors? I have a fbo system and was told to hook it up this way. Also, do you time the engine with it hooked up or not? In the Eddy carb setup book it says to do it this way if you have a long duration cam, mine is 237/242 @ .050 and .590 lift.
