Rat Bastid
Dunamis Metron
Also on the gasket maker for the china walls it says to assemble hand tight wait a hour then torque. Is this really necessary.
Also on the intake bolts some are hard to get to with anything other than a wrench, how are you supposed to torque them?
I have never torqued an intake manifold in my life. Nor will I ever. It’s a 3/8 bolt, there are 6 per side. Pull them tight with a wrench and send it.
BTW, that 3/8 bolt in grade 5 only needs 38-42 foot pounds of torque. A healthy 10 year old girl can pull that with a wrench. No disrespect to healthy 10 year old girls intended.
Also you need o go back over those bolts after a couple of heat cycles. They will loosen up.
