tires
moparraceman
mansfield ohio
does any one make a street t1re like mt streets for a 14" rim, all i see is 15" rims ,have a new set of cragers 4" bolt pattern 14x7 that i want to put on my 1971 valient need like a 14x7or 14x8 wide tire, something that will bit ,360with 904, good motor, any help would be appreciated thanks
Yes, at least according to a few months old summit catalog
M&H makes a bias treaded drag tire 235/60x14, 25" tall,7.5 tread, and
Hoosier quick time pro 26/9.5x14 bias, 26.1" tall, 8.0 tread.
The Hoosier is dot legal, but basically a stiff sidewall slick, with three grooves.
The Hoosier would be the better dragstrip tire.
I can get you part #s.
Out of a December 21 summit catalog....
M&H, MNH-MSS002
Hoosier qtp, HOO-17411
Editv numbers still good in a june 2022 catalog.....
I bought the M&H musclecar DOT bias ply tire for dragweek. With a stock offset rear wheel it gets about 1/2” from the rear leaf on my car. Works well.
