Big block help please. I am fixing a leak on my 440 oil pump. I have pulled it apart and have the o rings to go back in it. Once together, should I prime it before starting since so much oil ran out when I pulled it apart? Or just put motor honey on the gear and shaft and crank it for a while before starting? If I need to prime it....how do you do it? Thanks for any help.
