You'll have to pull the rotor off, take the vacuum advance off and the pickup plate out. Under that is the centrifugal advance mechanism. If it's adjustable it'll have 2 small allen head screws and when they are loosened you can slide the plate to limit the amount of advance. It's the same mechanism that a Mallory dist. uses so you can go by their adjustment description in this article.
http://prestoliteperformance.com/Po...structions_comp_s-s_distributor_32_series.pdf
You'll see it says there is a key set that when used gives a precise amount of advance. In other words use a key marked 20 and you'll have 20 degrees of centrifugal advance.
As I mentioned earlier if your dist. doesn't have an adjustable mechanism you'll have to weld up the slots to limit it. It's a little tedious cause you have to be careful not to get it all slopped up with weld. To bad your not close to me as I've done numerous ones. Only takes me about 30-40 minutes to set one up and phase the rotor. If your interested I have a good article from a magazine that spells out how to modify it if you have a non-adjustable dist. It's too big to post here but if you want it PM me with your e-mail address and I'll send it to you.
