scott_s
My '65 Valiant has the manual top, cast frame with offset linkage. The FSM shows some adjustments but I don't see the screws they are talking about on my top.
I don't see the set screw at the canter rail/rear rail. It's saying to adjust that to make the front fit the header better.
Can I also use the adjustment screw on the header latch (section AA, center pic) to make minor adjustments?
