top help needed
Dennis Gerard
Florida/tenn
1968 Barracuda , got the top working up and down with power to the motor from a battery, but when hooked up to switch nothing.
Wires run from motor to dash and one wire drops down from under dash to a relay? on switch.
Can someone enlightening me on where does it get the power 12V from?
I believe that there is a circuit breaker, possibly behind the drivers kick panel. It is worth checking.
no circuit breaker behind panel FYI But figured it out, The wire that drops down from under dash is power wirer, other 2 that go to switch are up or down reversing flow to motor, so I believe my switch is bad..
