1969GTS340
Hello FABO.
I'm curious on how a converter that flashes at 3800 RPMs in a 3200lb car with 500HP
would act in my car with 325HP and approximately the same 3200lb weight? Will it remain the same or be higher or lower? I'm planning on a new custom built converter for next season but considering this used converter in the interim. Appreciate any light you guys can shed on this and understand more info may be required to answer the question. Thank you
