ok heres the problem its a stock looking converter built to 2500 stall, will it be tuff enough for a strocked 528 cu hemi dyno at 700 hp and 680 torque. It will be street driven 3.75 rear gear no slick, tranny builder said its fine. All the donut shop racers say no way it will grenade.
Not even close to good enough. Will likely grenade and trash the trans. in the process. Like Poison and Clint said spend the money for a good converter. After all you've most likely spent a small fortune to build a 700 HP Hemi, haven't you? A good converter will most likely cost less than 7-8% of what that engine cost
