Torque Specification for Upper Ball Joint to UCA
fastdart69
Active Member
Illinois
Is there a torque specification for tightening the upper ball joint to the upper control arm. I know the spec for the nut to the spindle is 55 ft. lbs. I have searched for this on the forum but haven’t found it. I have the small upper ball joint tool for half inch drive. Thanks!
Mymopar.com
Download your year factory service manual.
That is your best source of info
Mymopar.com
Thanks for your response. I have a hard copy of the 1969 Service Manual. I didn’t find it in the manual either. I’m working on a 1969 numbers matching Dart Swinger 340.
I found this
67 FSM Section 2 page 13 says 125 minimum. and if they cant get to 125 min inspect the threads
Same section 2 page 13 in the 69 FSM
67 Images below
