Torsion Bar Advice... !!
pastortom1
Zephyrhills, Florida
Guys.........
Working on a 74 Dart Sport........Driver's side has sagged, enough to really notice.....it looks stupid.......I cannot visibly detect any appreciable leaf spring arch loss, although I know it probably has SOME.........BUT, the front drivers side is as low as the back end.......the shocks are both dry, and recover nicely........don't see any collapse there...........
Could this be a simple torsion bar adjustment for the drivers side?.......I know all I have to do is slightly lift the drivers fender lip and the back comes right up where it belongs............honestly, the drivers fender lip is actually a little BELOW the top of the tire tread............
What would you guys do here? Front and rear shocks are OK...rears are Gabriel air, and the bags are both good and no leaks.....front shocks OK too.....rear leaf is probably a LITTLE weak, BUT not THIS much......
What to try first? :dontknow:
I would crank the bar up, drive it around, then see if it still sags.
