I can't find these on rockauto. Anyone know where I can get them? The rubber boots or bellows that are on the torsion bars? They are on the crossmember end of the torsion bar.
Before I order the poly ones from Summit. What if my "spring clips" for the torsion bars (if that's what you want to call them "spring clips") are bad. Or for sh*ts and giggles I just want to replace them. Where can I get those?
I like the poly units because they appear to be more durable...to me at least...the standard rubber boots when I had them in hand, felt like they wouldn't last long, and tear easier...
Also, you might wanna boil your new poly boots in hot water to loosen them up a little, and lube the torsion bar, they will slide on much easier!
