1. Keyeserin
    Keyeserin FABO Gold Member FABO Gold Member
    17
    0
    Feb 13, 2016
    Oxford, Wi
    Local Time:
    11:33 PM
    I have a 69 Dart GTS that the torsion bars squeek. How do I eliminate this noise?
  2. BigBlockMopar
    BigBlockMopar BigBlockMember
    1,572
    523
    May 1, 2011
    Netherlands
    Local Time:
    5:33 AM
    What made you certain the torsion bars squeek?
    There's nothing that could squeek on a torsion bar, unless something is maybe moving against it.
    Bushings however can squeek.
    • Agree Agree x 2
    • Keyeserin
      17
      0
      Feb 13, 2016
      Oxford, Wi
      Local Time:
      11:33 PM
      The noise is coming from the front of the torsion bar. Are there bushings made that don't squeak?
    • Murray
      Murray FABO Gold Member FABO Gold Member
      877
      457
      Apr 19, 2010
      San Jose, California
      Local Time:
      9:33 PM
      It's more likely that the lower control arm bushing is squeaking. Use penetrating oil to locate the squeak.
      • Agree Agree x 1
      • 1969reddart
        1969reddart Well-Known Member
        215
        150
        Sep 29, 2007
        Concord, Ca.
        Local Time:
        9:33 PM
        I had a squeak coming from my front end (front of the torsion bar). I just pulled my front suspension apart and the lower control arm bushing was toast.
      • MOPAROFFICIAL
        MOPAROFFICIAL Well-Known Member
        3,022
        2018
        Jun 1, 2016
        breakwater
        Local Time:
        9:33 PM
        Poly bushings can do that, mine do everytime I get in the car and go over bumps.
      • Keyeserin
        17
        0
        Feb 13, 2016
        Oxford, Wi
        Local Time:
        11:33 PM
        I'll check the control arm bushings. Thanks for all the tips.
      • 72bluNblu
        72bluNblu FABO Gold Member FABO Gold Member
        9,097
        3082
        Nov 28, 2008
        NorCal
        Local Time:
        9:33 PM
        That’s because they’re not properly lubricated.
        If they haven’t been changed recently, they’re probably just worn out stock bushings in need of replacement.
        • Agree Agree x 1
