[WANTED] Torsion bar
Three threads for this in random places seem odd. But, if you have a number I can look at the ones I have and see if anything matches.
I would recommend replacing the torsion bars in pairs. You don't know how many miles are on a used one — it may not have the same effective spring rating as the one you have. And you are just as likely to find a matched set as to find a single.
I agree with mvh above. Need number off bar to match given you did not specify engine, ect. to correctly identify the one you need. I would not break up a set of bars myself so again his advice is worth considering. Plus upgrading to a larger diameter set is a very affordable way to improve driving characteristics.
I have some singles. Kim
Okay I need a driver side torsion bar I believe it's even numbers if I'm not mistaken the picture of the single torsion bar in my hand is the passenger side torsion bar. I'm only looking for a driver side please and thank you they are for a early a body 1965 plymouth barracuda.
