Total wiper arm removal
Mo Power
Ok so I decided that I wont need the wipers or wiper arms. So I was wondering what needs to be removed to take off the arms and so I can just put plastic plugs where they were and just leave motor setup there intact?
Remove the wiper arms from the cowl,crawl under the dash board and remove the arm from the wiper motor.Remove two nuts per side of the wiper transmission assembly and remove.Undone three nuts and remove wiper motor.Trace wires back and remove them from clip,remove wiper switch and wiring,remove fush from holder.Make plates for under dash holes and secure(seal also).Make plate for firewall or remove studs and mig a plate in.Simple,eh?
