tr6060 to LA bellhousing
madmax2
Active Member
Buenos Aires, Argentina
Hello !!
need put a tr-6060 (t56-magnum) transmission behind a LA-mopar (418ci strocker)
QuickTime sell one for T56 no T56-Magnum.
MP sell the P5155286 but have the starter inte passanger side, I think it interferes with the oil filter adapter. Anyone tried it?
I have an eraly A-body with LA-engine and TTI headers.
so I was inquiring and measuring I'm going to have to modify a OEM bellhousing, cut... shorten and weld an adapter plate.
Any advice or suggestions?
Try wilcap to get adaptor from block to GM bellhousing.
Using an adaptor is how Mopar To Ya got use a GM 200R4 into his dart.
the Challenger bell is for 11" clutch and 14x tooth flywheel.... other problema.
I called QuickTime, they answered the bell I need is a custom order and it would take 6-8 weeks and would cost $ 950 ... WOW
I have one of these adapters I'll part with if you can find a T56 gm adapter bell.
