honcho
How many qts does the tranney hold??? I need to change mine as it has been sitting up for 15 yrs. What about oil??? What are you guys using in your /6's?? This is my first /6 Thanks:blob:
Thanks I will be changing filter also,so I will pick up 5 qts just to make sure. Are you running a straight 30wt oil in engine??
