tranny huh
duster70
New Member
iowa
I have i believe a 727
number PK3743423
torque converter measures 10" bolt center to center.
what size flex plate should this use on a 318 ?
any place out ther sell both flexplate and torque converter ?
and is it true you have to cut gear off of old converter and weld on to new converter ?
A lot of places sell flex plates, try Summit Racing. Any new torque converter I've seen for a Mopar has the starter ring welded on all ready.
no you dont cut off the ring gear...
if you have a 10" bolt circle on the converter...
your flexplate needs a 10" bolt circle...
