It seems like the folks that want reuseability are the ones who have leaks. Why would anybody want reuseability when gaskets are cheap? A reuseable gasket costs about ten times more than the cheapest gaskets; 7-8 times more than the Duprene non-reuseable. If you're going to be taking your pan off a lot, then buy a cast aluminum pan and use the cheapest gasket you can find, or just silicone. Tin pans leak because they distort; that's it; and then they aren't straightened properly. Steel pans have to be straightened every time they're re-installed. Even the cheapest gasket wouldn't leak if it wasn't for pan distortion.
