The situation:
Parts car 73 Dart is in the driveway with the front end on jack stands and rear tires blocked. Engine has been removed and tranny is still sitting in the car. The driveway has a grade to it such that the car would easily roll backwards if left to its own devices.
My question:
I want to of course remove the tranny so I will remove the drive shaft and then remove the tranny cross member. If the e-brake is on and the back wheels are blocked then there shouldn't be any need for concern, correct?
I will be needing to roll the car backwards to put it on the curb so that I can finish the disassembly (removing rear axle assembly). I am not sure how I am going to accomplish this without any braking (having removed the front discs and the master cylinder already). Any ideas?
I am basically just doing a sanity check here to make sure that things are done in a safe and orderly way. All thoughts/suggestions are welcomed.
My question:
