[WANTED] Trans cross member
They are pretty easy to modify as long as you have a welder. Did mine a little different than how cosgig did his - mine follows the same curvature as on the passenger side crossmember - basically a mirror image of the driver’s side.
Here’s the way I did mine. Passenger side is to the right and is form fitted to the transmission crossmember.
