TRANS GO SHIFT KIT QUESTION
squeek360
edmonton
Can I get a trans go shift kit and only install the portion of the kit that allows you to "grab low at any speed"?
....... My issue is that I have an old mopar performance shift kit that was put in the transmission about 15 years ago...and it is the type that replaces the seperator plate in the valve body etc. , so I wouldn't be starting with a stock valve body and don't wanna risk installing the full trans go kit hoping it would work well with the mopar performance kit already installed.
the only real issue i have with the transmission is that it won't grab low above 1400-1500 rpm, anything slightly above 1500(sometimes even slightly lower) and it'll hydraulically lock me out of 1st gear and only grab 2nd....this drives me nuts because most of the speed limits around here put me at about 1600-1700 rpm(at 40mph) so all I want to get a trans go for is to get the grab low at any speed feature...so, it would definitely be nice to be able to just install that part of the kit
thanx in advance, hopefully somebody knows cause for that feature alone, it'd be worth dropping 70 bucks on a kit :)
Do you have the throttle valve adjusted proper?
That would be my first port of call. Check the adjustment of your throttle pressure(Kick-Down) linkage
Well I never thought I would say this but, if you have a floor shifter, I would put in a manual shift valve body. I have one in my 69 727 reverse manual, and it is great as far as I'm concerned.
It gets set to maximum pressure, allows crisp (understated) shifts at any speed. The valve body came assembled and set up. The best thing is NO BS kick down linkage.
Why not contact the tech department of Transgo. They'll advise you what you can and cannot do. And as fishy68 says mixing different brands of kits may not work.
If my failing old memory serves me correct, I believe that Mopar Shift kits were repackaged kits from Turbo-Action.
If you want to try it, I have the plate and screws from my kit you can have for postage.
Seeing has how the "Low at any speed" valve is just one single modified valve, I think it should be fine to swap in that part only.
I have one in my 42RH trans and my car has hiway gears so I can drop into low at 40 and it puts me right in the neighborhood of 4k where the cam likes to build power, so it pulls like crazy to 55 in low.
