plumkrazee70
I replaced the filter And pan gasket on the 904 and put 5 QTS in it and started it in neutral and let it warm up. I continued to add fluid until it showed full on dipstick. I moved it out of the garage (about 20ft) and back again. I went out there a few days later and there was trans fluid everywhere. I checked it out and the only spot I can see it leaking was from where the dipstick tube meets the pan.
I fired it up and the stick was on the add 1 pint mark. I haven't filled it back up yet. I did remove the dipstick tube to see if the o ring was bad and it puked fluid out of that hole. Is that normal with the tube removed?
Was it over filled? Did I install the filter wrong?
Thanks for the help and sorry for the long post.
70 dart 340 auto.
70 dart 340 auto.
