fishy68
Tyr Fryr's Inc.
Bummer Geoff. Sounds like the direct clutch pack is toast, like Trailbeast mentioned.
There could be a problem using a 66 trans. with a 71 engine. The 66 has a smaller converter register. 1.55" vs. 68 and up of 1.81". You can get an adapter ring to take up the difference so maybe someone has put one in when they did the install. Or someone could have installed a newer input shaft to use a newer torque converter. Count the input shaft splines and it their 24 it's a 68 or newer. If their 19 it's a 67 or older.
