If you want to for temp until you get the rods and parts together, or if you order Lokar stuff you can tie the TP lever on the trans half way back.
It will shift a little later and harder at low throttle, but you can drive it normally this way and it won't hurt it.
Don't jump on to hard though until it's fixed because tied back half way isn't enough pressure for WOT runs.
