mopowers
Would a sintered bronze vent be too restrictive to be used as a transmission vent?
auto or man. ? they work. easy to blow thru.
Auto. I'm relocating the vent and happen to have an 1/8" npt sintered bronze vent on hand.
I would use it
Try it and see. It it blows all the seals out you'll know it was too much restriction. I'm not bein smart, just tellin you what'll happen if it's too much restriction. Why take a chance?
I just tried a little experiment. I found a vent for an 8-3/4 rearend, and when I blew through it, it has about as much restriction as the 1/8 npt bronze vent, and it's quite a bit bigger. After that test - albeit, completely non-scientific - I'm pretty confident the bronze vent will be fine. It doesn't take much to relieve pressure in a closed system.
When the time comes, I'll probably end up running a catch can anyway, so it'll probably be a moot point.
If your relocating it to the tailshaft be aware that the governor assy will probably throw fluid out of the vent. That mod is generally only used in race apps where you remove the governor assy. Are you having a problem with tossing fluid under hard braking? If not I'd leave it where it is
