Transgo instructions Page 3 note 2
Mojoe9955
NJ
According to the directions on page 3, note 2, it says to plug this tiny hole in the partion, yet it doesn't say with what. Any suggestions? Thanks
Aluminum or copper (less effort to form ends) solid (versus stranded) wire or nail. Squeeze in place to make the ends bigger than the hole on both sides of the wall using channel locks. Both ends need to be bigger than the hole. The hole size can be slightly increased if needed to fit the wire/nail. A nail could just be bent if there is enough tail to hold it in place but no way it could touch the valve. Perfect seal is not necessary.
Don't use epoxy or any hardening liquid that could crumble and let go with age, exposure to atf, and heat cycles.
I found an 1/8" rivet stalk was a perfect fit. I remove the actual rivet sleeve which left the head, and cut it to length and was able to push it down and some how finagle it around to break off just right and leave enough to mash the end to secure it in the hole. I did nick the top edge of the valve body a little though. If there's a next time, I'll try a piece of solid copper wire which will probably bend easier while trying to secure it. As long as this system has been around you would think "Mr Shift" would have a plan for this situation.
Is "he" a member here? I think I saw that, but didn't have much luck with the cotter pin, nor was it mentioned in the directions.
MoJoe, I'll have to look in some of my instructions. It may have been in another kit and I assumed it was the TF-1,2, 3.
Tom Hand
