Hi All,
I currently have in my car a 727 (1975yr) that has a Shift technologies, Shift correction kit. It works ok, but I dont like the way it kicks down and the short hold on first gear.
I have a (1977) 727 that I borrowed the VB from and put the transgo kit into it. Now the directions say to put the PR adjust screw flush with the retainer. If I put a 1/8" or so space between the retainer and adjusting screw, it will give me more line pressure, Correct, or should I leave it flush and that be enough pressure?
The (77) VB, the kickdown lever pushes the KD valve in much sooner than the current VB (75) that is in the trans now, which is partially the reason for changing. Do you think I should just adjust the pressure higher on the (75) VB or continue on with my plan of changing?
I also have the Mopar Performance shift improver kit, which contains the servo's, springs and sleeve. I had also thought about putting it in while I have the trans apart. The directions on it says to adjust the PR adjustor screw to have almost no threads remaining, which kinda brings me to the first question of leaving some space on the TransGo kit?
I hope I did not confuse everyone too much.
