transmission casting number identification
5211833 I would guess is in the 1974-80 range.3743423 is for a 74' 904, and the numbers go up from there. My book stops in 74'. Hope that helps.
PK= assembly plant-kokomo plant
next 7 digts,part number,you have 8 digits,copied down wrong or extra number
last 8 digits are two sets of 4 digits.
The first set of 4 digits are the build date of the tranny=2083 which is wrong as this date is april 1967,and the part number is late 70,s or early 80,s.
The last 4 digits 2647 is the unit number built at that plant.
Take a few pictures of the serial number on the oil pan rail and post them or send me the pictures and I decode the tranny,mrmopartech penstarperformance@gmail.com
I searched far and wide and checked the numbers again and again with no luck. I then called a mopar transmission builder in Washington State, Pat Blais. he told me that it is for a 1994-1996 dodge van (non-lock up type). By all accounts it looks exactly like a 727 but I didn't think they made them in the mid 90's? Any thoughts?
