jeffs67dart
Member
I have a 67 dart with a 360/380 hp crate engine with a 904 with a 3000 stall converter and it has a reverse manual valve body, I'm going to use this car for mostly cruising but occasionally take it to the track. it has a trans cooler in the trans but I'm going to run a external cooler in series with the cooler in the radiator. my question is can I use 1/4 inch hose with an fittings? the reason I want to is I have I/4 inch hydralic hose and fittings already. I know I should use 5/16 inch but just wondering if 1/4 inch would be enough I am also running a deep aluminum pan.
