Transmission identification a833
Manual Transmission & Clutch Discussions
  1. MagnumBarracuda
    MagnumBarracuda Active Member
    31
    9
    Aug 20, 2018
    Valders
    Local Time:
    6:28 PM
    Trying to learn more about my 4-speed. I have Passon's book but im still not finding too much. The tail shaft is stamped "C39126-3" or "C99126-3". The book says the 99126 was used from 69 to 71. The car its in is a 67 barracuda and the car it is believed to come out of is a 72 duster. What does the -3 mean? The VIN on the case is not readable but it is stamped "C99129-L" on the main case not the side cover. The book doesn't say anything about that. 20200501_112546.jpg 20200501_112550.jpg
  2. dicksmidlac
    dicksmidlac FABO Gold Member FABO Gold Member
    307
    622
    Jul 6, 2005
    Thunder Bay Ont
    Local Time:
    6:28 PM
    I think it’s from Dec 1973.On the machined pad where it says pp833 use the last 4 numbers.Go to max wedge.com click on 10,000 day calendar.Type in those numbers in the search box and it tells you the date.
  3. mcodecuda
    mcodecuda Senior Member
    548
    139
    Sep 17, 2007
    Catawba NC Just a little north of Charlotte
    Local Time:
    7:28 PM
    Based on the date code of 4521 it was the 4 thousand 2 hundred 12th transmission built at New Process Gear in Syracuse NY in December of 1973. This would have been installed in 1974 A-body. Don’t discount the fact if the tail shaft case doesn’t match the main case because someone may have rebuilt it from parts. I’m currently rebuilding my 64 4-speed transmission using internal parts and tail shaft parts from a 68.
    • Like Like x 1
    • dodge71demon
      dodge71demon Well-Known Member
      3,321
      483
      Apr 29, 2009
      Indiana
      Local Time:
      7:28 PM
      64 to 70 were ball - detent
      71 and on were interlock
      But that also could have been changed
    • Alaskan_TA
      Alaskan_TA Well-Known Member
      5,522
      3752
      Nov 12, 2004
      PA
      Local Time:
      7:28 PM
      It appears to be 4B 274212 but a better photos would help?
      4B indicates that it came from a 1974 model year car built at Hamtramck.
