Transmission mounts
bb66cuda
San Jose, CA
I am looking for transmission mounts for an early a body, but haven't been able to find any. Are reproductions made for these cars?
Quote:
Originally Posted by djwhog
Yep all I see is the single stud version I need one with 2 studs. Anyone have a source???
OK< I Knew I had seen one someplace.............
http://www.imperialservices.net/defa...les/IS-102.gif
1961-1965 A-Body (1961 225 only)
Automatic and Manual Transmission Mount
Replaces P/N 2265 836. All new steel brackets with polyurethane insulator. Top bracket zinc-dichromate plated for corrosion resistance. Can also be used in place of single stud '66-'70 mount above by drilling a second hole in your crossmember. Excellent choice for high horsepower, manual transmission, or sticky-tired cars. Two mounting studs like the originals. Includes serrated locking nuts.
IS-102 - $79 + shipping
http://tinyurl.com/2j6964
1965 Dodge Dart
3.7L, 6 Cylinder, Gas, Carb, Base
SKU QTY PRICE
EM2272 $7.78
http://www2.partstrain.com/store/pr...ransmission&subcategory=transmission_assembly
NAPA
Item#: BK 6021121
Price: $8.99
does it also fit the v-8? I think all mounts are the same on the early crossmembers? Anyone know for sure?
All the mounts I've come across have just one stud on the bottom, even the ones listed as 65 and 66. All the crossmembers I have all have 2 studs on the bottom.
Hmm....
Well if it was me, and I had No tranny mount,
and had a single stud mount to use,
I guess I would have to get my 1/2" drive electric drill out;
and drill another 3/8" hole. ;)
You can also call Shumacher.
http://www.engine-swaps.com/
Also: (not shown) '62-65 B 4-speed, '63-66 A V8 style, $75+$9 S&H.
Phone
(206) 364-7151 - 7am to 5pm Pacific time
Fax
(206) 440-5464
Email
mschumacher@speakeasy.net
If you wish to get ahold of us Monday through Friday, between 7am and 5pm Pacific time, the fastest way is by phone. We are not always able to respond to emails as soon as they come. Please do not send emails with attachments, except by prearrangement. Any email sent with attachments will be deleted.
OK< I Knew I had seen one someplace.............:colors:
http://www.imperialservices.net/default_files/IS-102.gif
I'm just looking for standard rubber replacements, don't need the poly ones. Guess I'll put a second stud into a single stud mount.
