1. Pedal assy with clutch pedal.
2. Rod from clutch pedal to z-bar and boot
3. Bellhousing ballstud bracket frame ballstud, and frame ballstud bracket
4. Z-bar and seals, bearings, clips
5. Linkage from z-bar to clutch fork
6. Clutch fork
7. Fork pivot
8. Bellhousing ,boot and dust cover
9. Throwout bearing assy
10. Clutch and pressure plate
11. Flywheel
12. Pilot bearing
13. Transmission, 1966 -1974 "A" body A833 or 1975-1980 "A" or "F" bodies A833 OD
14. Floor tunnel
15. Shifter
16. Shifter mounting bracket
17. Shifter linkage
18. Shifter stick
19. Shifter ball
20. Bolts and fasteners
This does not cover differences in trasmissions, standard or OverDrive. If you are replacing a 904, 998 or 999 automatic transmission, your driveshaft will work if you get a small, 26 spline, output "A" or "F" body 4 speed or OD. If you have a 30 spline output shaft 4 speed or OD, you only need to change input yoke and rebalance your driveshaft. Shifters should be Hurst Competition Plus 64-65 "A" body with reverse lever stamped 2336, or 68 up shifters with reverse lever stamped 6353 (these can be found on 68 up "A" and "F" bodies, 68 and 69 "B" bodies, and 76-87 up trucks with the A833 OD manual transmissions). I would stay away from the inland shifters. There are other combinations but these are the "easiest" and use noncustom parts. Check out Passon Performance or Brewers Performance. I have all but decided to swap in a 4 speed OD into our 1967 340 Barracuda. If I do I will document it and share it here with pictures.
