512Stroker
We are all here because we are not all there.
This is a factory rubber mounted tail housing weight that Chrysler engineered to dampen drive train vibrations. They do work well.
This weight mounts in the factory location via a 2 inch bolt pattern.
Freshly rust treated and epoxy painted, ready to mount. Includes bolt plate.
$32 plus the ride. I believe this will fit in a USPS flat rate box.
