moparstan
Member
A typical 3/8” drive SAE socket set with a Ujoint and couple of extensions will cover 98% of your needs on a ‘65-‘75 Mopar car. About the only thing larger than 3/4” would be the oil drain plug (possibly 7/8”) and the harmonic balancer bolt on the engine (1-1/16”?? if memory serves). A piece of pipe for the wrench handle for “persuasion” is a good thing.I am preparing to travel to Washington state to pick up my 383 Valiant and was wondering what size sockets and wrenches to take with me. I am driving back to Florida. I am limited to 100 lbs of luggage on the train so eliminating unneeded sizes would be good. The aluminum floor jack and jack stands take up almost half of that.
What is the largest size wrench/socket that would be needed?
Are there any of the intermediate sizes that are not used? For example, on air-cooled VWs, you don’t need the even sized metric wrenches except for the 8 and 10 mm.
I am new to Mopars. I have a fairly extensive set of SAE (and metric) tools.
If you might be working under the dash a 1/4” SAE socket set would also be good and takes very little additional space and weight.
There will be no metric anything on a pre-1975 Mopar.
I swear by my rechargeable 18v Milwaukee 1/2” drive impact wrench and take it on all trips now. With 1/2” SAE impact sockets.
Electrical tools (multimeter, stripper/crimper, etc) would also be good, especially if the car is not known to have been a daily driver. A set of wiring diagrams (maybe on your phone) too.
I personally think if you must have a floor jack and stands it would be much wiser to buy them there (Harbor Freight or Northern Tool or even WalMart) than to haul those big heavy things with you. Driving home there is no weight limit.
Inspect tires carefully (all five!) and replace if they are old, cracking, or low tread. You are planning on a long drive and good tires are essential. Some tire sizes for older cars are getting difficult to find; I just replaced the tires on my ‘73 Dart and used P195/75R14 (hard to find), the originals were D78-14 (P185/75R14) (impossible to find) but I have a /6, yours probably had/has larger/wider tires.
If the ignition is original I would bring a spare ballast resistor, electronic ignition unit (or points, rotor, and condenser). Other than that it’s too hard to predict what you might need and you can’t bring a semi to haul spare parts.
Good luck and post some pictures of the car and your trip.
