gen2hemi
former ASE knuckle buster
- Joined
- Mar 15, 2010
- Messages
- 63
- Reaction score
- 1
Complete TKO600 EXtreme 5 speed set up by American Powertrain (aka ProFromance, aka Driven Man), 650 ft lb + rated, blueprinted transmission.
No abuse, 300 road miles.
Incl mechanical speedo adapter/cable, back up light harness, neutral safety harness, Sidewinder shifter (positions shifter left of tranny centerline for .tunnel humps) and yoke for 1350 u-joint. Note: Sidewinder uses an external shift rail on top of the tranny. Transmission can be converted to any of the TKO case-mounted internal shift rail locations (3) by swapping several parts.
Uses a Ford spline clutch disc and pilot bearing. You will need the correct pilot bearing for your crank.
Ships from WA.
$2800 + shipping
$3100 with B/RB/Hemi QuickTime SFI scattershield + shipping
Ships from WA.
$2800 + shipping
