[WANTED] Tri power center carb
68fsh
looking for direct connection mechanical Holley 4782 center carb for 340 six pack. Or just the base plate part. My base plate ear broke off. Thank you
I would call Holley, or promax, Scott harms, etc... about what might work or interchange for a base. After all it's just a 350cfm 2bbl. One of them may be able to repair it also. Btw these carbs flat out rock!! Keep the jet size close to stock even if using them on a SB like I am!
Thank you EL5demon340 for that info. Merry Christmas!
View attachment 1715123985 I would call Holley, or promax, Scott harms, etc... about what might work or interchange for a base. After all it's just a 350cfm 2bbl. One of them may be able to repair it also. Btw these carbs flat out rock!! Keep the jet size close to stock even if using them on a SB like I am!
QUOTE="EL5DEMON340, post: 1971923283, member: 9009"]View attachment 1715123985 I would call Holley, or promax, Scott harms, etc... about what might work or interchange for a base. After all it's just a 350cfm 2bbl. One of them may be able to repair it also. Btw these carbs flat out rock!! Keep the jet size close to stock even if using them on a SB like I am![/QUO
