1969 barracuda fb any tricks to remove window trim and drip rail /window mouldings prior to paint//any photo's out there ??[/QUOTEFor First block out plenty of time with no distractions (this can be tedious).2. Maybe have a couple beers on hand. I used compressed air to blow away debris under trim first ( I had a vinyl top and it was rotten). For the window trim I bought a tool for this purpose. The one I got was pretty cheezy and the handles needed bending back often but I got through it. Blocking out time will allow you to get into a groove/figure out a system. I also used wd-40 or PB Blaster as a lube and many of the clips were rusted. The trim on other parts of the car have different clips and require a different methodolgy and tools. I used worn in screw drivers etc. and took my time, as a result every piece of trim on my car is in almost perfect shape and reusable.
Good Luck!
