Trouble bleeding Wilwood brakes
joes68340s
Rescue CA.
Having trouble bleeding wilwood brakes. Cant get all the air out. Anyone else have this trouble. Any tricks. Thanks
yes..on my 71 Demon i put new front and rear strange brakes on it...
Used a pressure bleeder ....took care of the problem...
Ive heard that if you crack the transfer line that connects the 2 caliper halves, it helps in some cases.
Have you tried just opening the valve and let it gravity bleed for like five minutes. I would just do one at a time farthest away just like typical bleeding of system. I have had mixed results doing that. Some times it will work, other times not so much.
