Dartman1969
69 Dart Custom
I would also pull the PCV valve out of the valve cover and make sure it is still intact. I have seen them fall apart.
~Michael
~Michael
keep throttling. I tried that already too.:banghead:Can you just crank in the idle speed screw to keep it running or do you have to keep working the throttle to keep it going?
Then it woulda been doing this for the past 2,000 miles, correct?
Nope, I had my negative batter cable fall out of the terminal because some old guy messed with it when I helped him on the side of the road. He thought he was tightening it to the battery but he was actually loosening the wire from the terminal.Hate to go in a completely different direction. But, did the tach and the stalling happen at the same time? Could the tach have shorted something in the ign system causing a very weak spark? Just throwing out ideas at this point.
i would hate to think something inside the carb took a crap
definitely need to rule out everything outside the engine. id hate to see you go through all that just to have the same problem
choke is kinda wacked out, but its just the thermostat. Normally, it stays open because when I first got it running and timed it to 12* advanced (maybe a lil more) the choke would suffocate the enginedoes it have a choke maybe its stuck that would make it run like crap
that's what I did to it so it stays open Terry. It did that for a whiledisconnect the choke and fix it in a open position and see if that helps
can you explain again exactly what its doing? it wont idle? but it will run with the throttle? if thats the case it sounds like its running out fuel. i hate to keep beating this death but im not there LOL
it wont idle for long and it will run with throttle.can you explain again exactly what its doing? it wont idle? but it will run with the throttle? if thats the case it sounds like its running out fuel. i hate to keep beating this death but im not there LOL
I am in the same position. Trying to help figure out what the problem is from across the internet. :banghead:
In order to keep it running do you need to pump the accelerator pedal or just hold steady throttle pressure?
~Michael
Yeah, I did that. It keeps it running a little longer now that I have it running higher now. Does that help any?have you tried jacking up the idle screw to keep it running? its sounding more and more like a bad fuel pump to me. just because its new doesnt mean its good
Edelbrock Air gap. No EGRWhat intake are you using? Does it have an EGR valve?
~Michael
