True formula S 383 car? data plate attached
johnnycuda
JohnnyCuda's 68
Hey all is this read correct D-9 = disc brakes F-7 = formula S
also reads orig 383 car bright blue mettalic side stripe
wheel lip mouldings drip rail mouldings bucket seats
Uploaded with ImageShack.us
F7 is the most important, yep "S" car. Not sure on the 383, mine is a 69, so I am more familiar with those fendertags, but Im sure you can find a decoder on line. Yours, or you thinking of making it yours??
CAR: Plymouth Barracuda 2 Door Sports Hardtop
ENGINE: 383cid 4-bbl HP V8
TRANSMISSION: 3-Speed Automatic
TIRES: E70x14 Red Side Wall, steel belted
BUILD DATE: October 02.
AXLE: 3.23
INTERIOR: Deluxe Trim Grade, Vinyl Bucket Seats. Light Blue Interior.
PAINT: Monotone Bright Blue Metallic Paint.
OTHER: Light Blue Metallic Upper Door Frame Color.
MOLDINGS:
19: Wide Sill Mouldings
25: Drip Rail Mouldings
30: Body Belt Mouldings
78: Wheel Lip Mouldings
ABC OPTIONS:
D9: Front Disk Brakes
F7: Barracuda Formula S Package
R1: AM Radio
T4: Vacuum gauge
X1: Tinted Glass (all)
abc OPTIONS:
a6: Console
b4: Bucket Seats
m6: Driver's Outside Remote Operated Mirror
Thanks Rocky
the int came up blue when i try to decode it you sure that is correct?
and the paint is QQ1 which is bright blue poly too. Is thaT CONSIDERED b-5?
mostly correct to what i got just wasn't sure and wanted to confirm.
AXLE: 3.23
MOLDINGS:
ABC OPTIONS:
R1: AM Radio
T4: Vacuum gauge
abc OPTIONS:
a6: Console
b4: Bucket Seats
I assume this is a 68 model. I redid before you posted I was off a notch, it is probably real close to a b5 blue, but is not.
