Trunk Divider Insulation
Links
Member
Delaware
What side of the divider does the insulation go on, Seat side or trunk side?
Seat side. It hangs on the two metal ears to which the upper section of the sets connects.
So on the seat side of the carboard divider board? Sorry didnt make the ? clear enough. Installing new divider and insulation and didnt know if it goes in front or behind the board.
Yea it hangs on the hooks that hold the top of the seat in place. The divider goes on then your back seat
OK, I didnt know what side of the board it went on. I though I remember the insulation up against the seat so when you look in the trunk you would see the divider board and not the insulation.
Yes that is correct, all u want to see is the divider board
Seeeeeeeeeeeeaaaaaaaaaaatttttttttttttttttsssssssssiiiiiiiiiiiddddddddddddeeeeeeeeeeee.
