kielbasavw
65 valiant slant six motor. Carter bbs. I've tried everything to smooth it out right off idle. I got mixture set from turned in out till idle quits rising. I even tried little extra rich and a little extra lean. Tried moving accelerator pump rod to the other adjustment points. And doesn't seem to affect it. Timing is set at 5deg. at about 800rpm if I remember right. Carb has good squirt and is rebuilt. Distributor is new. I have done factory electronic conversion. The only thing I have not tried is advance adjustment through the pod. But that is something I haven't ever done before. No idea where to start from or if that would even affect a flat spot.
Any help would be great
