Use some sharp miniature pcb cutters cut the small legs off first if you overheat & try to remove you can tear the pad off the board.
Then use a nice hot iron & some solder to quickly heat the small legs & remove dont put the iron on the leg & let the iron heat up.
The parts will come off when ready dont try to force otherwise it will damage the pad they will take a bit of heat as the solder will be high temp to cope with the high temps .
Once you remove the 2 legs get the iron smoking hot then place on the tag of the transistor & apply the solder the solder should flow quickly allowing removal the trouble with the tap is normally they are soldered to a copper plane that uses a large area of the pcb allowing it to dissipate the heat
Sometimes the 2 small transistors beside it may be fried they are the drivers for the larger unit they are footprint SOT23 1 will be PNP the other NPN
The damaged unit is a 3055L n channel mosfet available from Mouser P/N 512-NDT3055L
