TTI block off plate and 6.1
Rat Patrol
On the outskirts
A supplier has raised doubts about whether the TTI block off plate will fit the 6.1 oil filter boss.
Has anyone used the TTI plate on a 6.1 and can verify?
TTI stuff works and fit perfect the first time everytime.
Thx
5.7 - did you use the TTI mounts?
If so - how did you find the engine height?
Did you have pinion angle issues at all ?
Tti mounts, headers with their full exhaust on an early b body (64). Everything dropped right in place, driveline angle was easy but I do not remember what it is. I also used the 45 degree adapter from ma mopar. The engine height is set from using tti mounts and shumacher poly loc mounts on the factory k frame.
Rat Patrol,
I have one and it looks like it should fit no worries. I am no using it as when modifying my k frame made it so I could use the stock filter so if you want one PM me.
Cheers
Graeme
Thx
I was hoping you ran an A body.
Im interested in the result people may have had with the A body "biscuit" mounts and TTI adapters.......Ive been told they really elevate the engine and set up a dreadful pinion angle.
Anyone else had this experience?
If you happen to remember the drivelive angle please share as I have mine car nearly complete but have a vibration around 80 when it shifts into o/d. Thanks ;0)
-C
