TTI Header Flange
Dartwizer
Member
Mississippi
Does anyone have pictures of the head side of the tti flange?
These would be going on the Indy X small block LA style head.Has anyone installed tti headers on the Indy X head? I know they will bolt on,just wondering about the match up to the ports,,,,thanks in advance
Don't have pics but have been running mine on the RHS {Indy} XHeads for 7 years , I use the thick graphite gaskets that compress to prevent the dreaded header leaks .
PS how port matched do you think you need on the exhaust side ?
My concern is with the shape of the ports on the header vs the head.Will they block flow?
I have a few pics from a 68 we just did... They had 318 2v heads and wanted TTI's so the corners needed filling. Customer is always right. They fit tight but nice. After some adjustments getting the engine in just the right spot, they were great. No dings required.
